Karl, it simply uses a "pull-type clutch" as was used in HD trucks.
When the clutch pedal is pushed to the floor the TO bearing moves rearward and squeezes the clutch brake disc that is splined to the pilot shaft between the TO bearing carrier and the face of the cover ahead of the output shaft bearing to bring the drivetrain ahead of the transmission to a halt.
Do you know what is wrong with yours... does it simply need adjustment, is it worn out, or is it worn free o the pilot shaft?
I can send you instructions on adjusting the pedal travel and the brake linkage, and you can view the parts breakdown at the link below by entering the model # in the search box, then selecting the parts catalog matching the year of your tractor.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
