Re: Un-seizing adjuster screws on Hay Rake?
Posted by BarnyardEngineering on April 05, 2016 at 06:59:43 from (40.141.236.245):
In Reply to: Un-seizing adjuster screws on Hay Rake? posted by blunosr on April 04, 2016 at 22:16:34:
It's going to take eons for anything to soak in as far as those threads go, if it ever does.
You need HEAT. Oxy-whatever heat. Propane, acetylene, MAPP. Pick your poison, they all work. Put the tube in the vise, heat it evenly and keep trying to move the crank every little while. Maybe try to wick in a little bee's wax if you have it.
Once you get it free, clean everything up with a wire wheel, let it cool, and slather a bunch of grease on the threads before you put it back together.
