Re: Let's talk spark advance again.
Posted by Steve@Advance on June 06, 2016 at 20:53:28 from (107.203.134.67):
In Reply to: Let's talk spark advance again. posted by David G on June 06, 2016 at 19:53:50:
That's some interesting stuff!
Thinking about the dimensions of your engine vs. an automotive engine...
Smaller bore, longer stroke, lower RPM power range, low overlap cam, all add up to less advance being needed.
Another factor is rod length. The longer the rod, the longer the TDC dwell range. Takes more degrees of rotation before significant movement of the piston, gives more time for the flame to spread. So would the 17* still apply?
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
