Posted by JD Seller on October 06, 2016 at 13:07:13 from (208.126.198.123):
In Reply to: Planting Rye posted by David G on October 06, 2016 at 07:30:41:
If your planting Rye grain then about 1 1/2 bushels per acre, about 84 lbs. per acre. This is thick enough for cover crop. IF your going to green chop it then we always plant 2 bushels per acre.
Also the Rye you plant this fall will grow a lot come spring. It will need to be sprayed or plowed under to kill it come spring. It will not die off until it is mature next July.
If you are wanting some thing easier to kill off next spring I would plant winter wheat. It is much easier to kill. Plant 2 bushels per acre if broadcast 1 1/2 if drilled.
If you had been a little earlier Oat work the best. They will grow up to a foot tall in the fall and then winter kill. It is too late for oats now. mid Sept is about the best.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
