Posted by Steve@Advance on October 15, 2016 at 20:58:40 from (107.203.134.67):
In Reply to: IH 400 died, no start posted by super99 on October 15, 2016 at 18:24:41:
I suspect the points are corroded. The corrosion inside the cap says water has been getting in the distributor, condensing inside the cap. There may still be water in the distributor...
Try cleaning the points with contact cleaner and wiping them with clean paper. Or just replace them.
Then check for spark at the coil. If still no spark, put your test light from the point side of the coil to ground. Turn the engine over, the light should come on each time the points open, go off when they close. If the light stays on, the points are not making contact. If the light never comes on, there is a short in the wire to the distributor, the points are closed, or there is no power to the coil. Check the ignition side of the coil, if no light, there is a bad connection from the ignition switch, or the switch itself.
If all that checks out, and still no spark from the coil, the coil is bad.
Back to the water in the distributor. There can be water pooled in the bottom of the distributor housing, especially if stored outside. When the engine starts, the heat boils the water up, it condenses under the cap, shorts out the high voltage. Be sure the distributor is dry. Blow it out if possible, or leave the cap off, get some heat on it from a light bulb or hair dryer. The corrosion under the cap is usually harmless unless it's severe or carbon tracked.
Have you looked inside the non-foulers? Sometimes they pack up with carbon and need to be cleaned. That is not why it won't run, but it can cause miss fire and poor performance. If you do end up replacing the plugs, might try to find hotter plugs and remove the non-foulers. It there a thermostat and is it working? Getting the engine up to temperature?
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
