Re: Spark Jumping From Center Lug On Coil
Posted by John T on December 20, 2016 at 04:31:47 from (71.54.163.172):
In Reply to: Spark Jumping From Center Lug On Coil posted by KCTractors on December 19, 2016 at 19:14:54:
When you start using high voltage capable high energy after market ignition systems especially if running wider plug gaps resulting in higher firing voltages, if the coil top and its HV tower and the cap and rotor and plug wires aren't all in good shape with no hairline cracks or carbon traces or faults THOSE PROBLEMS CAN REAR THEIR UGLY HEADS. Id be checking the coils top HV tower for carbon traces or cracks and the coil and plug wires for a break or open that allows the voltage to rise too high so it jumps where you mentioned. Try a new set of coil and plug wires if the coil is okay !!!
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
