Re: OT wiring an AC lamp socket
Posted by Steve@Advance on December 21, 2016 at 13:02:10 from (24.182.105.179):
In Reply to: OT wiring an AC lamp socket posted by Dave H (MI) on December 21, 2016 at 11:43:15:
Being the wiring is that old, good bet that is only a 2 wire system with no ground.
To determine which is the "hot" wire, you'll need to ground one lead of the volt meter to something metal that is in contact with the ground, like a water pipe, metal siding, etc. Then touch the other lead to each wire. The one showing a reading, 110-120vac will be the hot.
Be careful disturbing that old insulation, trust nothing!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
