Re: 1030 Case Hydraulics.....
Posted by Adirondack case guy on January 31, 2017 at 08:43:54 from (69.207.198.19):
In Reply to: Re: 1030 Case Hydraulics..... posted by banjoman09 on January 31, 2017 at 06:22:02:
third party image
Your hoses supplying the loader valve have to be hooked with one hose in the RH side coupler and one hooked in the opposite LH coupler, top or bottom. Once you have done that, you then have to determine which way to lock the corresponding remote lever to feed the inlet of your loader valve and not feed the outlet. You can switch hoses to change lever direction if desired.
Scroll down to the Case forum, with further questions. Us Case guys are not grumpy old tractor nuts, but we expect not to have to repeat simple instruction more than once, especially how to hook up the remotes.
Loren
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
