Re: Engine will not break in?
Posted by jimg.allentown on May 27, 2017 at 18:04:32 from (173.49.133.204):
In Reply to: Engine will not break in? posted by tomstractorsandtoys on May 27, 2017 at 12:57:41:
After reading all of the other comments, here are my thoughts:
Just having been overhauled does not insure that it was put together correctly. It was put together by a human, and humans do occasionally make mistakes. Like not checking for the proper ring size. Like having all of the ring gaps lined up. Like not having a proper hone finish in the cylinder bore. There could also be issues with valve stem seals.
Regarding using any abrasives, I would say use extreme caution. While they may aid in seating the rings more quickly, they may also linger and cause premature wear of the rings/pistons/bores. So, once you put them in, how long does it take to get rid of them?
For diagnosis, I might suggest that you do a leakdown test before taking anything apart. That would help to either prove or disprove a ring problem.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
