Re: Wheel clamp locknut
Posted by Royse on February 02, 2018 at 18:03:10 from (69.36.53.231):
In Reply to: Wheel clamp locknut posted by SVcummins on February 01, 2018 at 20:45:41:
The ones I used were the same style, different size.
As JD Seller said, leave the outer locknut loose, BUT make
sure it is on there when you thread it on. Otherwise the sections
will spread apart and you may not be able to get it back on.
Not to mention the outer one being kind of snug helps keep it
from stripping out while you're installing it on damaged threads.
