Re: Lawn Tractor Mechanic Needed...
Posted by Steven-id on March 02, 2018 at 15:42:19 from (216.201.68.11):
In Reply to: Re: Lawn Tractor Mechanic Needed... posted by philip d on March 01, 2018 at 20:25:48:
I have a rider that had the same basic issues you are talking about. What I found is my fuel pump runs off of a pulse line in the motor. The diaphram had ruptured and when stopped it would load the crankcase through the pulse line. In my situation a fuel shut off would not have worked. The new fuel pump fixed that problem. The starting problem on mine was the valve settings. There is a number on the side of the motor that you need to look up and see what specs to use. Mine the valves are set at I believe about 4 degrees after tdc. Check the specs and set them just like it says and it will make a world of difference.
Steven
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
