Re: Property Line Question and Pushy Neighbor
Posted by NY 986 on March 12, 2018 at 06:50:07 from (184.53.49.110):
In Reply to: Property Line Question and Pushy Neighbor posted by Howard H. on March 11, 2018 at 19:23:06:
Now that you have heard the coffee shop talk it is time to see a local lawyer to see what pertains to you. I will say that around here a licensed surveyor's work will normally standup in court. The other half to that is it might take him a little doing to find a suitable benchmark depending on the situation so the cost of the job might run more than what was expected. If a judge questions a survey job he will order a second survey perhaps by a different surveyor if suspects an issue of competency. After that point it is very seldom that a significant difference is seen in two survey jobs. The only way a wide variance becomes a lasting issue is because two benchmarks that are considered good lead to that. Then you get into state surveys from around 200 plus years ago and then that gets expensive to sort out. NY killed adverse possession around a dozen years ago so at least here nobody can stand on that leg. Before that was terminated there was all kinds of shenanigans going on with strong willed neighbors preying on others.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
