Posted by smschumaker on April 02, 2018 at 13:56:55 from (166.181.85.147):
I have a 4960 that used to start great but now won't start unless it's plugged in or over 50 degrees. The engine blew a head gasket last August after a head bolt snapped. I replaced the gasket and bolts and made sure the liners were good, they had great Cross hatch on them yet and there is no blow by at all. It was starting hard but I thought it was just the blown gasket because after it was replaced it got better for 2 months untill the weather turned. Like all 4k series when it started it would rev up and then settle at idle. It slowly started to loose that and now it won't do that at all it just cranks and cranks and then just idles.
I screwed the aneriod screw all the way in to gain a little more power up top which helped alot. I thought that had something to do with it so I screwed it back out but it didn't help. I'm thinking governor springs next, any ideas?
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
