Re: Rubber restoration.....truck or tractor...
Posted by Grandpa's Fords on April 04, 2018 at 09:36:01 from (50.32.105.199):
In Reply to: Rubber restoration.....truck or tractor... posted by banjoman09 on April 04, 2018 at 06:41:22:
I used to soak previously used asphalt race car tires in the swimming pool for the week between races, Would get another heat cycle out of them. That was in the summer with water about 80 degrees.
They would get pliable again, non synthetic rubber tires got so hard that you couldn't stretch enough to dismount 3 days after using.
I'd definitely try hot water. Or if you know somebody that races they may have rubber treatments I know they make them.
I think the molecules just get all excited 8)
