Re: Tracter 12 volt conversion kit
Posted by old on August 25, 2018 at 14:22:53 from (72.251.71.97):
In Reply to: Re: Tracter 12 volt conversion kit posted by Bando on August 25, 2018 at 14:18:54:
Amp gauge goes that high due to you discharging the battery trying to get it to run. As for coil getting hot is it the 6 volt coil that was on it with no ballast resister or did you put on a true 12 volt coil that says on it no ballast resister needed?? If it is the 6 volt coil it will get hot and the points will get burned up and can also fry the coil
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
