the water injection cools the combustion chamber to eliminate pre ignition from the red hot carbon deposits. My son's pulling tractor uses a quart and a half of water in 300 feet to keep things from melting, his is injected into the manifold just like most of the old kerosene tractors. If you look up the Nebraska tests in will show that the oil pull used almost as much water as kerosene under a heavy load as they had pretty high compression for the day. Most all of the old tractors just used a valve that you manually regulated but the Kingston carb on the oil pull had a chamber for the water and regulated it. An IH 15-30 also had a dual chamber carburetor. Our hart-parr juust used a manual valve.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
