Diesel injectors should not be tampered with unless a poptester is available to check and adjust the opening pressure. Need to know what the pump make and model is too, some Fords have Simms inline, some have DPA rotary, some have Delphi DP 200 pumps. Later New Holland Fords have Bosch rotary or inline pumps. Without that info you will get all sorts of advice, some right and some wrong.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
