Re: Farmall H Axel Locking Up!
Posted by Janicholson on January 13, 2019 at 07:10:36 from (24.240.46.228):
In Reply to: Re: Farmall H Axel Locking Up! posted by Deeskii on January 12, 2019 at 19:54:56:
Nut shell list.
Support rear housing on wooden cribbing
Disconnect battery cable
Drain both sumps (trans and finals)
Clean all dirt from platform bolt holes
Disconnect/support steering column
remove seat
Remove bolts
Use balanced sling in seat and steering threaded holes
use a thin stiff putty knife to separate top
Lift straight up to clear shift forks
Look to see the real issue
Remove the axle nut (between gears down in there)
Slide axle outward to clear gear
Lift bull gear and clean up parts
Remove bearing
If the gears are chipped smaller than a lima bean I would probably use them after dressing to smooth with a dremel
Also check the pinion for nicks or burrs
Re assemble (I would use the black RTV sealer on clean metal for the top. Just a thin layer fingered on with a poly glove)
Jim
