Re: Enough battery for starting motor but not for spark?
Posted by redforlife on April 01, 2019 at 08:38:22 from (68.234.121.189):
In Reply to: Enough battery for starting motor but not for spark? posted by JohnV2000 on April 01, 2019 at 06:28:33:
Problem is more than likely one of two things. #1. When the starter is spinning, it is using/robbing all the juice
from battery and none going to the ignition. If this is the case, you should be able to charge battery, jump
start, or pull start. #2. It could possibly not be getting enough juice to ignition system for other reasons.
Frayed wire, bad connections, bad key switch, etc. This can be checked out with key on, starter not engaged with a
test light, or meters.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
