Several things I can see, first of all I think that you have a RWA disc not KBA. Second you have the wrong hydraulic cylinder on it. You need a 8 inch stroke with double acting pressure so as to get the wheels up out of the dirt so when you are disking the dirt that the disk is throwing does not touch a wheel and leave a ridge. Next you can throw away the stones, bricks and firewood as the wheel frame should be all you will need for weight. Next comes the leveling screw on the tongue needs to be adjusted so that the front gang is deeper and the back is shallowed up till it is level. Also you will need to use it till the blades all get scoured and clean and that none of them are partially loaded. All scrapers must be properly adjusted to keep blades from loading. Without a furrow filler attachment you will always have the outside rear furrows but the next time over or a pull behind drag of any kind will level those out. Hope this helps. Tom
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
