Thanks for the pictures, same appearing throttle linkage (only longer) as on my 730 Gas. I had minor low RPM issues and at the front of the engine rt. side needed to adjust the stop on the rod forward. A stretched screen could be an issue. On the 730 front left side of engine was an adjustable linkage from the governor to carburetor that required adjusting length. Yours maybe the same. The 730 has good power 16-1800 RPM with PTO 1700. Carburetors can be a problem and also distributor's with broken advance springs and/or advance weights frozen in a fixed position, been through all theses issues.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
