Re: Engine knock after carb change update 2
Posted by kencombs on August 21, 2019 at 06:33:40 from (108.208.32.113):
In Reply to: Engine knock after carb change update 2 posted by Morgan in ar on August 21, 2019 at 03:50:34:
Just a suggestion. When you start the head removal, try taking the exhaust manifold off first. Then take a look in the port at the valve. Long shot, but whatever it is may be stuck under the valve causing it to hit the piston. Again, long shot, but you may be able to loosen it and pull it out with the head on.
If you don't find anything, no loss as the manifold needs to come off anyway.
