Re: G governor
Posted by popinjohn on August 26, 2019 at 18:15:15 from (24.171.7.83):
In Reply to: G governor posted by hoipigeons on August 26, 2019 at 10:48:42:
On a John Deere, the stub shaft that stick up out of the governor
housing on the LH side (flywheel side) gets water inside and
binds due to rust. Usual fix is some WD-40 and some engine oil.
The governor arm with the flat spring attaches to this stub shaft,
and if binding will cause the problem you describe.
