Like others have said Teflon tape. If you wanted to get a permanent seal. Tap out the drain plug to the closest pipe plug. Might be 3/8 pipe. Then drain the oil clean the threads super clean, and epoxy the original plug in. It may be a problem getting the threads clean of oil. Mc Master Carr has led washers which should also work. I epoxyed a drain plug in a aluminum saddle tank on a Volvo FE7. Holding good for a lot of years. Stan
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
