Posted by unc on November 07, 2019 at 18:48:09 from (23.190.128.58):
In Reply to: Blue steel? posted by Geo-TH,In on November 07, 2019 at 15:37:26:
So is a drill bit junk if tip turns blue?[/quote]
If a bit is very old (say 75 years) or very cheap, it may be made of ordinary high carbon steel. If the cutting edges have turned blue, you are on the edge of reducing it's hardness.
Most bits today are made of high speed steel. This steel contains alloying elements that allow it to keep it's hardness at low red heat. You're probably okay. unc
Upload one or more videos to your post. Photo and video filesizes should be less than 8MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
