Posted by Morgan in ar on November 16, 2019 at 16:39:06 from (167.224.209.179):
A couple of months back, I had something get sucked into the intake of the 283 in my 65 chevy C20. Upon disassembly, I found a damaged piston. At the time, I decided it would be a better option to replace the piston and rings, than to go with a salvage engine. Apparently that was a bad call. When I finally got it reassembled and started up, it still sounded (and smoked) like a perkins diesel. I called around and the neighbor has a couple of 70's model trucks with small blocks that he is parting out. I guess I will have to go that route. I think I will save the original engine for a full rebuild. My engine hoist didn't work. Somehow the plug came out of the cylinder along with all the oil. I had to use the farmall. I will probably need to get the hoist working for reassembly.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
