#1 you think the firing order is right well you need to be 1000% sure #2 so get #1 cylinder at top dead center and watch the rotor as you do that so you know which direction it turns as the engine turns over. Then make sure you do have the firing order right. #1 cylinder is by the radiator. Firing order is 1,2,4,3 #3 once you have the firing order correct check that you have a good blue/white spark at the center wire of the distributor cap and at the plug wires that will jump a 1/4 inch gap or more.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
