Posted by MarkB_MI on February 25, 2020 at 03:48:42 from (174.245.17.0):
In Reply to: Floor hoists posted by Al Baker(pumpman) on February 24, 2020 at 09:00:21:
My BIL sold his two post hoist and replaced it with a four post. He LOVES his four post.
I don't believe most four post hoists need to be anchored, but check with the manufacturer. It might be it only needs shallow anchors, say a couple of inches deep; if that's the case you probably won't drill deep enough to hit the tubing.
If you decide to drill for anchors, I would pressure check the tubing with compressed air once you're done. If you find a leak, you can then decide whether or not to break out the concrete and repair the line. At least you'll know if you hit a line or not.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
