Posted by jimtrs on March 24, 2020 at 09:35:59 from (73.16.69.78):
In Reply to: Head Gasket posted by super99 on March 23, 2020 at 15:17:06:
IF gasket sealer IS required, it will say it on the gasket. If it does not, most types would be OK with something - Copper Coat, Permatex Avaiation sealer, etc.
As said, if it the rubberized type of gasket, with sealer around holes, do not add anything.
Adding sealer will not do anything / interfere with the fire rings (metal ring around cylinder that seals the combustion chamber). All sealer is basically squeezed of of these when the head is torqued down.
Sealer aids in sealing around water ports, oil ports, etc. It helps keep water and oil from leaking into each other or to the outside.
Upload one or more videos to your post. Photo and video filesizes should be less than 8MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
