Re: Plastic plug removal
Posted by used red mn on April 10, 2020 at 21:27:21 from (75.73.112.20):
In Reply to: Re: Plastic plug removal posted by Steve@Advance on April 10, 2020 at 18:06:18:
Going off how Steve summed up what you have going I will offer another possible solution. In a 1 in. plug you should be able to drill a hole large enough to stick a hacksaw blade ...broke off one held in a vise grip or plier maybe even a fancy holder if you have one...or even a saws-all if you have one. Carefully cut a slot out in the remaining section of the plug until you reach the threads. Be careful not to damage the threads when you get close to them. You may have to do this in a couple spots about a 1/4 in. apart. Then just crush the remaining part of the plug with a channel lock or drive it together with a hammer and chisel. Just buy a regular galvanized pipe plug and install it with a liberal coating of RTV on the threads. The RTV will hold down the corrosion on the pipe plug threads and you won’t need to crank it in real tight to make it seal. Other wise you could go all out and get a brass plug, I’m not sure how much one of those will set you back though.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
