> This guy said all you do washing under your vehicle is activate the salt etc.
Salt is hygroscopic, so unless you live in the desert, it will absorb all the water it needs to promote corrosion directly from the air. Not to mention any salt deposited on the vehicle is going to get wet every time you drive in the rain. The only way to stop salt from promoting corrosion is to eliminate it, which is admittedly not easy to do in many nooks and crannies of your vehicle.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
