Here in SE Michigan, straight #2 with anti-gelling additive is standard. We have an unoccupied house with a fuel oil furnace that only uses a couple of hundred gallons of fuel per season; I've found that the fuel tends to gel if it's left over from the previous winter. Adding a quart of anti-gelling additive to the leftover fuel each fall seems to protect the old fuel from gelling. But it seldom gets below -20F here; further north I can understand why a mix is desirable.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
