Re: Farmall F20
Posted by Farmallb on September 14, 2020 at 14:01:56 from (99.196.22.222):
In Reply to: Farmall F20 posted by Binderson on September 14, 2020 at 08:25:48:
Its been a long time since ive had a 20, and around 10yrs since I had my last 30. I cant beloeve
you cant get the wing nut off of the wide rad cap. You likely will need to replace the rubber
gasket underneith it. IF you do, glue it back onto either the cap of rad. Make it much easier to
replace cap then. I thought there was a 2in recessed plug with a 4 hole square indention that
fit a socket ratchet nicely somewhere around the floorboard, such as saying it had a floor board
lol. to fill with gear oil. I dont remember where the check plug was. The drop axples should
have the same on each, and when it runs back upt the fill hole, its full. You could take the cap
off the steering worm cover and check the grease in it., It should come up to around 1/.2 way
even with the work gears,.
I farmed with a 20 and 30 when I was a teen and in my early 20s. Had another 30 10yrs ago, but
the engine went bad. IF I was 50 or so, Id look for another.
