The reduced size is supposed to help with preventing the problem you are encountering at this time. It is smaller to give clearance for removal. I like diesel fuel for these jobs it soaks in better than anything I have tried. If you want to mix a bit of old engine oil in with it fine. Then just keep soaking for a few minutes then go do something else for a few hours. If no joy after trying this put a weight behind the fork and drive it out with a big hammer. The bigger the better you don't have to swing as hard, and if it moves it moves easier. If it doesn't move it will do no more damage than pounding repeatedly with the small useless hammer. I like 2-4 pound hammers for those reasons. If somebody can be twisting the bolt as you hit may do more than anything for it. Heating then cooling with water will crack the rust loose and will also tend to harden the pieces too.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
