Posted by old on January 17, 2021 at 12:25:54 from (67.142.112.66):
In Reply to: Re: Lift in ford 851 posted by Minnemomick2 on January 17, 2021 at 12:20:47:
Well then it is time to put a pressure gauge in the pressure port which is under the seat in that square plate and see if you have pressure. The unloader valve maybe stuck and if so the top cover has to come off and the -o rings be replaced in it
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
