Posted by Bob M on June 01, 2021 at 11:16:09 from (172.101.128.69):
In Reply to: Why do floats stick posted by SDE on June 01, 2021 at 10:47:27:
Like Old recommends I was taught at an early age to ALWAYS shut off the gas when finished for the day. Eliminates the possibility of filling the crankcase with gas.
I too have experienced intermittent float sticking. Most often it is a worn float pivot bracket, or a poorly made replacement float. But this also happened to my Minnie Mo U:
Ran it out of fuel once. Just as it quit it suffered a particularly explosive backfire - so violent it actually blew the hose off the carb air inlet.
Afterward the carb would randomly and unpredictably flood. After struggling with it a couple weeks I disassembled the carb. Problem turned out to be partially flattened carb float pontoons. Apparently the explosive pulse through the carburetor was powerful enough to flatten the floats slightly so they would randomly rub and hang up on the (rough) float bowl wall.
Today's Featured Article - Restoration Story: 1964 JD 2010 Dsl - Part 2 - by Jim Nielsen. Despite having to disassemble the majority of my John Deere 2010's diesel engine, I was still hopeful I could leave the engine-complete with crankshaft and camshaft-in the tractor. This would make the whole engine rebuild job much easier-and much less expensive! I soon found however, that the #4 conrod bearing had disintegrated, taking with it chunks of the crankshaft journal. As a resul
... [Read Article]
Latest Ad:
[More Ads]
