Re: Resistor in ignition circuit .... question ??
Posted by bc on June 03, 2021 at 06:33:20 from (24.255.129.137):
In Reply to: Resistor in ignition circuit .... question ?? posted by Crazy Horse on June 02, 2021 at 13:00:36:
I suppose the way to test the resistor is to see what the voltage drop is after the resistor. Might have to disconnect the negative from the coil but check the voltage leaving the ignition switch which should be the same as the battery (12+). Then check the voltage after the resistor or where the wire runs to the coil which will tell you what voltage the coil is getting. Ground the black test lead to the tractor to get your readings. If it reduces the voltage down to 6 then you would likely have a 6 volt coil, I believe or maybe it just drops it down enough to save voltage going across the points.
  Select Gallery Photo  Attach Serial # List
Upload one or more videos to your post. Photo and video filesizes should be less than 8MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
