Re: sprayer is spraying.
Posted by jon f mn on June 12, 2021 at 04:28:29 from (174.219.143.184):
In Reply to: sprayer is spraying. posted by rustred on June 11, 2021 at 20:49:24:
35 psi will be about the minimum pressure you can use. On mine I have 20 spacing and use 8003 nozzles, go 5mph at 50psi and get 20 gal/acre. The lower gallons per acre you use the more drift you will get and the more trouble with plugged nozzles you get. Make sure you have the proper screens in each tip as that will help with plugged nozzles.
