Posted by Steve@Advance on August 22, 2021 at 17:41:31 from (99.190.215.237):
In Reply to: Ford 841 update posted by grandpa Love on August 22, 2021 at 15:44:17:
If it still has the stock coil, the wire wires will work. Only with the flame thrower coils are resistor wires required, so I hear. But wire wires will not make it run bad, they are hard on the electronic unit.
Rapid, rhythmic popping back through the intake, worse under load or acceleration is usually caused by an exhaust valve not fully opening, a flat cam. Did you watch the valves opening while the cover was off?
It can also be cross firing, a carbon tracked distributor cap, really bad plug wire insulation between to wires touching each other, usually worse when damp.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
