Posted by Steve@Advance on September 04, 2021 at 12:26:20 from (99.190.215.237):
In Reply to: Jd 6400 tachometer posted by werk241@gmail.com on September 04, 2021 at 09:40:36:
Do you still have the old engine? If so look behind the tach sensor, see what triggers it, how many triggers pass by the sensor in one revolution of the engine.
Possibly the new engine has more triggers, or the old engine measured cam or pump speed, and the new engine is measuring crank speed.
If that is the case, what to do about it is another question.
Have you looked at the back of the tach? Possibly there is a jumper or a way to set the count ratio.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
