Assuming it was not charging, no harm should have been done.
Why was the battery removed? Not charging before? I would not be surprised if you still have a no charge problem. As others indicate install battery positive ground and then polarize generator.
Check voltage across battery. Full charge should be 6.3 volts. Start engine, rev to at least half throttle and check battery voltage. If 7 volts or above it should be charging. With fully charged battery the ammeter will show very little indication.
If voltage does not go up when running:
1. Ground field terminal when running, should show significant increase in charge rate. If so you have a bad regulator control, either in voltage regulator box or the combo light switch.
2. If still no charge, leave field grounded and jumper from ARM terminal on generator to the lead from the battery. If charge now increases you have a bad cut out. If still no charge suspect generator, wire,or grounding problem.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
