Re: To 35 stalls in warm weather using PTO
Posted by Steve@Advance on April 24, 2022 at 18:16:15 from (99.190.215.237):
In Reply to: Re: To 35 stalls in warm weather using PTO posted by M77hawkeye on April 24, 2022 at 16:56:35:
For the timing to be slow enough to raise the manifold temp, it would also be
having performance problems, loss of power.
You could try insulating the fuel line, getting it away from the manifold. Do
not insulate the manifold, it needs to dissipate the heat.
An easy test for the questionable fuel cap, just loosen it, see if there is a
difference.
I would somewhat suspect the inline filter. Paper filters are made for
systems with a pump, not gravity flow. You might can find a screen type
filter at a small engine supply. I have used the glass screw together type
with mixed results, they are prone to leak.
The difference you are seeing when the PTO is on is the increased load on the
engine. More load means more fuel demand and more heat generated.
About the coil, have you felt the coil when it fails? A normal coil will be
about the same temperature as the surrounding components. If it's too hot to
hold, something is wrong, bad coil or the wrong coil. Assuming this is a 12v
system, it needs a true 12v coil or a 6v with a 1 1/2 ohm resistor. Many
times coils are mis boxed. Either check the resistance across the primary
terminals or go by the part number actually on the coil, not just by the box
or what the counter man sells you.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
