Re: Woods mower drags engine
Posted by 710ltd2002 on April 30, 2022 at 13:24:21 from (172.58.122.234):
In Reply to: Re: Woods mower drags engine posted by Dave BN on April 30, 2022 at 12:47:09:
Bought it five days ago. The first day, it ran well enough to cut a few swaths, just kind of playing. The second day it began dragging the engine down. The carburetor: the seller used full choke to start it, about 45 degrees outside and I think it had been running before we arrived. Starting it a few times at home, gas poured out the carb (not every time). Today I adjusted the float to lessen the gas in the bowl. Too far. Engine surged and stalled. Adjusted it again. Ran beautifully unless pto engaged. Seeing Old old post, I adjusted float again to cut the gas a bit. No change to the pto issue. I dont know that I should keep messing with the float.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
