Re: Water Heater
Posted by Geo-TH,In on May 18, 2022 at 04:55:21 from (184.19.45.90):
In Reply to: Water Heater posted by john in la on May 17, 2022 at 18:50:07:
Agree with you:
2 new thermostats and a pressure valve.
Only replace elements when they go bad.
Test them with an ohm meter.
They make special elements that operate in sand.
Camco 02932/02933 5500W 240V Screw-In Lime Life Foldback Water Heater Element - Ultra Low Watt Density
240V/5500W
Best when water has high mineral count
Resists dry firing
Heats in lime and sand that would burn out ordinary elements
You may need lower watts.
If your elements aren't broken, why replace them??
