Re: naa ignition switch
Posted by warbaby on May 19, 2022 at 06:38:07 from (24.247.205.221):
In Reply to: naa ignition switch posted by mike/holly jones on May 19, 2022 at 06:21:47:
It seems unlikely. The keyed switch only supplies voltage to the coil at a few amps so there isnt (or shouldnt be!) a lot of heat-generating resistance going through the switch and wires . An old, original switch can have worn internal contact points and that could cause intermittent problems.
If you suspect the switch, just jump across the two wires on it the next time it quits- if it works then, I would definitely replace it.
