Block drain petcocks are usually clogged with sediment. You can take the petcock out and clean out the sediment with a stiff wire.
Best way to flush is to remove the thermostat or bypass hose so water will free flow through the system with the engine running. Hang the garden hose in the radiator, open all the drains, start the engine and run it up to speed with clean water going in and the dirty water and vinegar being flushed out. When it runs clear water, usually about 15 minutes of flushing, turn everything off, replace the thermostat or hose, let it drain, and refill with 50-50. Or use straight antifreeze and distilled water.
But, if it was full of rust, expect to have to repeat soon as there will still be rust in the bottom of the block. It may or may not stay settled, depending on how bad it got.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
