Posted by BarnyardEngineering on January 10, 2023 at 03:38:45 from (161.69.123.10):
In Reply to: Cutting tapered pipe? posted by big tee on January 09, 2023 at 17:58:20:
Now that you've got it cut to rough dimension with the chop saw, go back with the tape trick and establish a straight line. Use a sharpie marker to make the line, step back, and make sure it's straight. If it isn't, carb cleaner and a rag to clean off the mark, then try again. Keep trying until you're satisfied with the line.
Now get out your angle grinder and a cutoff wheel. Trim the tube, leaving the line. Switch to a flap disc and fine tune things up to the line.
Upload one or more videos to your post. Photo and video filesizes should be less than 8MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
