Re: I need a push button Normally open switch
Posted by John730D on February 06, 2023 at 06:10:48 from (162.211.34.254):
In Reply to: I need a push button Normally open switch posted by Geo-TH,In on February 06, 2023 at 04:59:10:
Switch---Go to Surplus Center.
Before you do that though, Clean all the safety switch connections. I had a Deere mower that would do exactly what you are describing. It had 4 safety switches after the ignition switch. After I cleaned up all the connections, it worked like it should. You get a lot of voltage loss through all those connections if they are dirty or corroded. After that, it just became an annual maintenance issue. Good Luck.
