If you had it tied down good in the trailer it should still be right where it was when you drove it in minus the tipped over trailer. So if it pulled loose either the tie downs are not very good or it was not tied down well. 4 3/8 chains or 2 hooked to trailer then a binder on each leg so it makes a loose draped piece in the middle on each end then one over the bucket should be good if they are the G70 chains with adequate binders.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
