The push rod falling out does not apply to you engine. ..She is a flat head.. is rustred using a short cut way if telling wore out that his suggestion of the pushrod being out of place does not apply to your engine because it is a ..flat head.. or valve in block engine. It is unusual for an engine to have sticking valves and read good compression. Just a few days ago someone had this same problem and found even though the compression was good when the valves had to move faster when the engine was running they were sticking just enough to cause the problem.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
